2 Pages<12
JRGwagon
#11 Posted : Sunday, December 13, 2015 2:59:53 AM(UTC)
JRGwagon
I have the same problem as noted above, with a Maytag range model MER5765RAQ. The "on light" for the stove top burners does not turn off, but all of the burners currently operate properly. Based on the previous dialogue, this leads me to believe that one of the infinite burner controls is broken. How do I determine WHICH burner control is bad? I do know which burner was operated at the time the "on light" failed to turn off. Does that imply that that burner control is the culprit?
#12 Posted : Sunday, December 13, 2015 3:28:51 AM(UTC)
JRGwagon
Parts for Maytag MER5765RAQ Range - AppliancePartsPros.com
It is the most likely culprit but the only way to tell for sure is to measure the switch contacts with a meter.
Take a look at page 11 in the tech sheet.
If I read the diagram correctly L1 to P ion the switches control the on light.
Unplug the unit and either L1 or P at the switch you are testing.
You have to do this because the switches from all infinite's are wired in parallel.
Measure across the switch contacts. Should be infinite ohms. If 0 ohms then that is the bad switch.
I would start with the one that was on when this fault first happened.
JRGwagon
#13 Posted : Saturday, December 19, 2015 2:42:01 AM(UTC)
JRGwagon
denman,
Thank you for the reply and also for the technical bulletin on this Maytag range. I am not an electrician, but do have capabilities to do some electrical troubleshooting and repair. Reading the schematics is a bit difficult, however. I see some schematic extracts and a PHYSICAL DIAGRAM of the switches, on pages 3 and 4 (5 diagrams are shown). Can you tell me which of these 5 diagrams I should be looking at to test the switches on this range? I assume that one diagram would be for the small burner and one for the large burner. That would be a huge help in diagnosing this. Otherwise, I will probably go with the assumption that the burner that was operating when the problem occurred has the bad controller.
#14 Posted : Saturday, December 19, 2015 6:36:36 AM(UTC)
It depends on the series number.
I believe that the series number is the first two digits in the serial number.
Not sure that I quite understand the above.
For instance looking at the first two diagrams for Series 11.
The first one shows the physical wiring layout re: plugs and wiring routing.
The second one is the same wiring but simplified so that it is easier to follow.
2 Pages<12
