I need to replace the soap dispenser and have seen the video to remove the front cover of dishwasher but it won't come off. I see on my model that I have one screw on the lower inside door that holds the door hinge and it looks like it does not connect to front then I have 2 screws on each side that i took off and the screws underneath the door but still can't move front panel off. Is there another screw hidden? Don't want to force panel.
Found out that I had to take all the screws out the inside door and pull the plastic inside door panel up to get off the soap dispenser. The front panel was attached with screws hidden by the inside door panel. This is for the GE GLD5604V00WW model not the way the video shows.
