123zorn
#1 Posted : Thursday, December 3, 2015 5:01:02 PM(UTC)
123zorn
My electric dryer just stopped working on Tuesday. It was a bit odd in that it just stopped, I attempted to restart, and it would not. I waited a good long while and it did restart after unplugging and waiting and it did heat as well (so the fuses were not the issue). But now it will not start at all. The fuses are good, it is getting power, the start relay switch is good. Suggestions on things to try? Is there a way to bypass the circuit board to test if that is bad?
#2 Posted : Friday, December 4, 2015 2:21:28 AM(UTC)
Parts for Whirlpool GEQ8858JQ1 Dryer - AppliancePartsPros.com
http://forum.appliancepartspros..._icons/editor/attach.gif
See the attachment for the tech sheet
[COLOR="Blue"]
Is there a way to bypass the circuit board to test if that is bad?[/COLOR]
This will not do you any good as it is not part of the start/motor circuit. It just controls the timer motor.
First I would check the power. Other wise you could pull the unit apart only to find the problem is not in the unit.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the wall receptacle
L1 to L2 should be 240 volts
If OK
If OK
If the power is OK.
Unplug the unit and set the timer to mid cycle timed dry.
Use you most sensitive resistance meter scale. Also before starting short the meter leads together so you know if there is a zero offset in the meter.
Attach one meter lead to the L1 prong on the line cord and leave it there. Now work your way through the start/motor circuit.
BK and BU on the timer should be 0 ohms.
Push the push to start relay. Both sides of it's contacts should be 0 ohms. I think the blue wires.
All further tests are with the push to start activated.
Both sides of the thermal fuse on the blower should be 0 ohms.
Both sides of the belt switch should be 0 ohms. I am assuming that the switch is closed.
4M on the motor should be 0 ohms.
5M on the motor should be about 1 ohm (motor windings).
Timer switch 4 (W to T) should be about 1 ohm.
Blue on the door switch should be about 1 ohm.
Activate the door switch. Now the other side should also ne about 1 ohm.
Neutral (white) on the terminal strip and the neutral prong on the line cord shoul also be about 1 ohm.
You should have found the open somewhere during the4 above, I hope.
Whirlpool Dryer will not start (Dryer Repair)
by saaman 8/21/2014 12:46:47 PM(UTC)
Whirlpool Dryer will not start, have power "sensing light is on" Replaced both thermi (Dryer Repair)
by joanu 11/21/2013 6:32:09 AM(UTC)
Whirlpool dryer will not start (Dryer Repair)
by vaughn quern 11/26/2012 9:52:02 AM(UTC)
by vaughn quern 11/26/2012 9:44:09 AM(UTC)
whirlpool dryer will not start (Dryer Repair)
by mikeshard 3/29/2012 8:49:17 PM(UTC)
Whirlpool dryer will not start. (Dryer Repair)
by c33341 3/11/2011 9:47:28 AM(UTC)
by Newglide 1/12/2011 6:54:14 PM(UTC)
by dafense 2/10/2010 6:13:16 PM(UTC)
by mbryans 1/7/2010 12:31:19 PM(UTC)
by rsqmedic8 7/26/2009 7:43:08 AM(UTC)
by bratsinc4 2/4/2009 6:05:06 PM(UTC)
