barker1959
#1 Posted : Thursday, December 3, 2015 12:52:30 PM(UTC)
barker1959
I have a 10 year old sears Kenmore glasstop oven and the burners on top of stove all work, but when I try to turn oven on and hit the bake button after 3 seconds it shuts itself off and F31 flashes...I tried unplugging it and plugging it back in but still does it...
#2 Posted : Friday, December 4, 2015 2:38:20 AM(UTC)
F31 looks like an open oven sensor.
Below is a link with info on how to check it.
Look at 7, 8, 20 and 21.
http://www.applianceaid.com/ele...-range-repair-topics.php
If the sensor checks out OK check the wiring to the control board and the connection for it on the control board. Could be a bad solder joint etc.
If all OK odds are that the control board is bad.
Part number: AP3969435
F31 code flashing when trying to turn oven on?? (Oven Repair (including Ranges and Cooktops))
by barker1959 12/3/2015 12:37:01 PM(UTC)
