wewildbill
#1 Posted : Friday, November 27, 2015 6:30:18 PM(UTC)
wewildbill
Freezer temp will only reach 30 degrees. Will not freeze properly. Is there a way to test control other then open or close.
#2 Posted : Saturday, November 28, 2015 5:10:12 AM(UTC)
[COLOR="Blue"]Is there a way to test control other then open or close.[/COLOR]
I am not sure what you mean. The control thermostat is just open or close.
If the compressor is on all the time then it is not a control problem.
The control is telling the unit that it is too warm but for some reason the freezer cannot get cold enough.
This is most likely a sealed system problem and will be an expensive repair. Often it makes more sense to put the dollars towards a new unit.
wewildbill
#3 Posted : Saturday, November 28, 2015 7:36:46 AM(UTC)
wewildbill
I thought that since it was a variable control that in moving from 1 to 10 you would see a change in resistance on an ohmmeter. For instance from 0 to 900 ohms. That the variable would be what caused the the change in temperature setting.
Thank you.
wewildbill
#4 Posted : Thursday, December 3, 2015 1:35:43 PM(UTC)
wewildbill
When you plug it in, it sounds like the compressor comes on for about 2 to 3 seconds then shuts off.
#5 Posted : Friday, December 4, 2015 2:56:46 AM(UTC)
Could be the compressor, the start device or the capacitor.
Below is a site with info on how to check these parts.
How To Fix a Refrigerator - Appliance Repair Guide - ACME HOW TO.com
I cannot find tech info on this unit so do not know if it is a start relay or a PTC (electronic) starter. In any case it looks like it is obsolete.
Note that if the compressor winding grounding and resistance checks will tell you if a compressor is bad. It does not tell you that the compressor is good as it may have internal mechanical problems.
If it is a compressor problem it is probably not worth fixing due to the cost of repair.
