Hi, I need to replace the spark switch on this cooktop and can't find what is involved in separating the glass top from the burner box. The parts diagrams do not show any screws or tape to hold the two together.
Thanks for any help
Kevin
I am in the same situation with a similar model glasstop, gas cooktop JGD8430ADS Jenn-Air which is 10 years old. Same exact question about how to remove the glass top before I go wrecking things.
