I am replacing the spark module on for my gas oven - repair man (v expensive to do repair) came and told i needed spark module and gas safety valve .. not sure I trust him .... so I ordered the spark module and I'm trying to replace it ...but I cannot disconnect the green ground wire to connect it to the new module ... is there some trick ... HELP?!
Got it off ... but didn't fix the issue :(
