My GE Profile Advantium 120 turntable is not working properly as well.... It turns without the tray, but will not turn when using either the glass tray or the metal tray (for convection/speed cook oven function).
Please let me know if you can help with this issue ... I would assume that possibly the shaft assembly needs replacing... but I can't discount the fact that the motor may also just be weak with age ... I would like to be able to just order 1 part or the other ... and not both ... since I would like to be able to repair it with just one time taking it out of service and taking it all apart ... Thanx, Adayton
