AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
dryer runs for awhile then shuts down before cycle is over
The dryer runs for awhile then shuts down before the timed cycle is over. Seems hot also. Also, door switch doesn't seem to turn off dryer when I open door.
Have you been able to restart the dryer right away or it took some time? Did it make a humming or any other noises at start up? - The part number for the door switch is AP3883929 Gene.
i have the same problem. whan dryer shuts down it will not start than makes a buzzing noise. if i wait 5-10 minutes it buzzes than starts.
Looks like this a motor.
For more accurate advise I need the complete model number of the dryer. Post it as a new thread, please.
Dryer Repair
