IGoofed
#1 Posted : Monday, November 16, 2015 8:06:12 PM(UTC)
IGoofed
I shorted my control board for my Frigidaire oven and received a replacement but there is no wiring diagram and the ones I have found on the Internet are unreadable (and in electrician-speak).
If I was smart I would have written down the old connections (as well as thrown the breaker before removing the control panel)
I have the following wires and terminal connections
Wires - Blue, brown, yellow, red, black
Terminals: L1, Broil, Bake, L2Out, L2In
Which wire goes to which terminal!
Thanks!
#2 Posted : Tuesday, November 17, 2015 12:38:03 AM(UTC)
See the attachment for a decent copy of the wiring diagram.
I do not know what the problem is with electrician speak so cannot help there.
Also note that I take no responsibility if you plug this in and it blows up.
Black (BK) goes to L1. This is electrical code
Red (R) goes to L2IN. Also code L2 is always red.
Blue (BL) goes to Broil.
Yellow (Y) goes to Bake,
Brown (BR) goes to L2Out.
At least that is how I tread the wiring diagram.
joandrum
#3 Posted : Wednesday, August 17, 2016 3:51:56 PM(UTC)
joandrum
Just wondering if this worked because I have the same problem with my Frigidaire model FEB27S5DBB. The wire colors and terminal labels are the same. The repairman who came for my home warranty replaced the relay, but a friend had to help pull out the oven and he disconnected the wires without noting the locations. The repairman looked at the diagram and placed the wires differently. I can't tell what area to look at to determine what goes where other than the blue and yellow.
Thanks!
#4 Posted : Thursday, August 18, 2016 2:56:19 AM(UTC)
Yes it looks like the wires are attached the same as the above.
Please see the attached wiring diagram for your unit.
joandrum
#5 Posted : Thursday, August 18, 2016 8:18:15 AM(UTC)
joandrum
Thanks. I had the diagram but don't know how to read it. One would think an appliance repairman would be able to.
#6 Posted : Friday, August 19, 2016 3:04:20 AM(UTC)
Since the repairman could not read it, I would not use him again.
This should be a piece of cake for any repairman.
Guest
#7 Posted : Sunday, February 18, 2024 7:06:05 PM(UTC)
Guest
Rank: Guest
United States
I'm trying to get a wiring diagram for a fridgedare oven motherboard
Guest (5)
