Ray Z
#1 Posted : Tuesday, November 10, 2015 2:50:15 AM(UTC)
Ray Z
This machine works perfect on delicate setting, fills and agitates on heavy & normal settings but won't go into the spin cycle.
sidfink43
#2 Posted : Wednesday, November 11, 2015 5:17:33 AM(UTC)
sidfink43
Since it will work correctly on one cycle that suggests there is nothing mechanically wrong with the machine and that you should change out the timer.
Replace it and that should fix your problems.
