dholleymosher
#1 Posted : Sunday, November 8, 2015 8:26:33 AM(UTC)
dholleymosher
There is power to the stove but none of he burners or the oven will heat. :confused:
#2 Posted : Sunday, November 8, 2015 9:54:15 AM(UTC)
How do you know there is power at the stove?
The timer and oven light run off of 120 volts but the elements require the full 240 volts.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the wall receptacle.
L1 to L2 should be 240 volts
If OK
If OK
