Originally Posted by: SuzeR ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) I also have a six-burner of indeterminate age, and needed two new ignitors - the dacor ranges use EXACTLY the same units and everything now works perfectly. My tech guy showed me how to blow out the gas pipes as they get filled with dust and grime over time and therefore not as much gas flows through. I'm ready to get rid of the remaining enamel on the grates and am having it all blasted off and the underlying iron sealed. It's as good as new! Hi SuzeR, I have the exact same issue with the exact same Russell Range Inc. MDL fsc-36-6 cook top and I am being told that if I can get the Dacor part number for the spark module from you that they will come fix my cook top. Your assistance would be greatly appreciated. Thank you.
I have in storage some vintage Russell Range 36" 6 Burner cooktop parts. Items are either brand new or near new (I'll have to check stock).
Porcelain Burner Grate: $50 each Cast Iron Burner Grate (unporcelainized from factory): $50 each Black Porcelain drip pans: $25 each Black Porcelain drip pan tray (each holds 2 drip pans): $50 each Black Porcelain back splash: $135
Shipping will be actual cost from CA, no added fees.
Hello, I am interested in the black back splash and maybe grates and drip pans. Please advise what you may have available? Thank you, Renee Gabet- Ligonier, Indiana ReneeGabet@gmail.com
Do you have any ignitors for the Russel Range 6 burner Stove Top?
Hi Sharpie, We have a Russell Range Model BIC-42-6. Two of our grates have porcelain chipped off. Do you still have any grates? Please let me know. Also…Wondered if you have an suggestions to finding a new Ignition Burner Switch for the same model. Thanks! Bryan
I need to replace the grates for my 6 burner Russell Range cooktop, no oven. Does anyone have a connection for Russell parts?
Originally Posted by: sharpie ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) I have in storage some vintage Russell Range 36" 6 Burner cooktop parts. Items are either brand new or near new (I'll have to check stock).
Shipping will be actual cost from CA, no added fees. I have a Russell 36' 6 burner cooktop. No oven and need a grate. Can you help
Originally Posted by: gumboprod ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) I have a Russell 36' 6 burner cooktop. No oven and need a grate. Can you help In my previous message I neglected to mention that the grate I need must be cast iron. No porcelain. Thanks.
The solution of the issue can be found on the internet. There are many solutions provided in google.com. I myself got the solution by using google.com
I want to purchase 6 black grates for my Russell range cooktop, how do I get a hold of Sharpie? Email me at soripp@aol.com
