My Whirlpool Duet Dryer Model #WED9200SQ0 will turn on and the sensing light turns on but it will not start. I put it in diagnostic mode and got an F25 error code. I replaced the thermistor but it still won't start and still shows an F25 error code in diagnostic mode. Any advice?
Did you check or change the thermal fuse?
