bobneel
#1 Posted : Wednesday, October 28, 2015 1:47:18 PM(UTC)
bobneel
The dryer heats up normally for the first 5-10 minutes, then cuts out and tries to dry on cool air. Start/stop doesn't fix, but resetting the cycle on the panel usually - but not always - does. However it still cuts out again after a short while. The heat won't come back on by itself during the cycle.
Bad temperature cutout switch or thermostat?
Bad control board?
Your thoughts are appreciated
#2 Posted : Thursday, October 29, 2015 3:13:48 AM(UTC)
The number given does not come up as a Model Number.
When I search it it comes up as a control panel.
Please check it.
