Hello: My Kitchen Aid KESC308LSSO range heat will not come on. When I set the oven temperature the displacy/control panel works and I can hear the relay clicking on but there is no cooking heat. All circuit breakers are on but it seems like there might be a bad heating element (??).
I am good with electronics and electrical stuff but I can't diagnose the problem so I come to the experts. Thank you in advance.
Jeff
Here are your parts Parts for KitchenAid KESC308LSS0 Range - AppliancePartsPros.comSee the attachment for the tech sheet. Do the stove top elements work? If yes then the power is OK. In the tech sheet you will see a 20 amp fuse inline with the elements perhaps this is blown. That fuse may be the one shown in the following part but I am not sure. You will have to trace back the wires to find the correct one. Part number: AP3132842
Be sure to check each element for resistance and that they are not grounded before replacing the fuse if it is blown. |
THIS FORUM IS DEAD!!!!!!! |
