The moisture sensor looks like it is OK.
You have replaced and checked the thermistor earlier and that also checks out OK, correct?
Could it be in the control panel it is possible but it is just a grasping at straws with no hard evidence that it is.
You seem to be getting weird errors all over the place. Check that the power coming out of the power cube is a good/solid +5 volts.
Am I correct in assuming that this unit did run OK at this location with the current electrical hookup?
The reason I ask is that error codes that are all over the place are often due to spikes on the line or a bad electrical hook up. point
At this point I am just making wild guesses as the troubleshooting does not point towards a bad part. |
THIS FORUM IS DEAD!!!!!!! |
Thanks for the help. I changed the board already, the thermistor in the intake and outtake and a thermal fuse. The only thing left if the sensing circuit harness and bar sensors or the control planet user interface. It seems to dry okay in timed dry but not on auto sensing. And I didn't change out the heating element.
it looks like the last thing I just did finally fixed it, I replaced the moisture sensing harness, not the bars themselves, just the harness with resistors in them, etc. However, when in diagnostic, the heavy duty light still does not illuminate and I believe that it should. Thank you again for all of your help and guidance.
Not fixed:(. Changed out the user interface and still have f25 and now it won't go off of sensing into wet, damp, etc. put the old board back in, f25 did not appear but same problem. Put new board back in f25 again but same problem. That heavy duty light still does not illuminate during diagnostic. Should I scrap the machine?
has been bookmark, this seems like a very interesting thread
