fan works along with light but not cooling or freezer what compressor run capacitor, damper control help with what to look for might save time and money thanks for any help darlene
Here are your parts Parts for Frigidaire FRS6LR5EM3 Refrigerator - AppliancePartsPros.comWhich fan is running or are both of them running? Is the condenser/compressor fan running? If yes, then the compressor should also be running as it is wired in parallel with the condenser fan. Is the compressor running? You can usually hear it but also should be able to feel it vibrating. |
THIS FORUM IS DEAD!!!!!!! |
