ron3033
#1 Posted : Sunday, October 11, 2015 5:19:25 AM(UTC)
ron3033
I have a few questions about this board. 9763042 in Whirlpool Range GERC4110SB2
1. Here is the video URL and my list of them: one deals with codes, one with broil feature when start is pushed.
https://www.youtube.com/watch?v=6XcH...layer_embedded
https://www.youtube.com/watch?v=2EYS...layer_embedded
Error Codes I get.
>cancel/cancel/ start up comes AM71 UI45 EEWET204
>then push hour up button up comes most recent code 0120
> then push hour up button up comes error code 2 0111
> then push hour up button up comes error code 3 01
> then push hour up button up comes error code 4 0117
> then push hour up button up comes error code 5 01H1
>When I touch all the buttons the range peeps. The top elements work. Broil>no, Bake>no, Choice Bake>no, Warm>no, Convection>fan starts, but no heat, Precision Clean> door locks and top element get hot.
Broil has odd looking numbers, though the numbers display are there when move them up and down, just mess up when push start.
I did get the rear board (9761909) from APP as they had it, still got above codes with it, so put my board back in.
So I assume the top range control board 9763042 with the clock is faulty. I do not believe it is the touch membrane, but some one said it is.?? I believe I need a 9763042 board???
I will have to or send mine to Appliance Timer and Stove Clock Repair and Replacement - Ranges, Washers, Dryers, Dishwashers for rebuild or CoreCentric Solutions | Adding Value from Start to Finish for a refurb as APP is out of stock.
Any advice 9763042 board or touch membrane? How can I tell for sure what I need? I need to fix this as I can't afford a new range
Been this way since Aug 23.
thanks ron3033
ron3033
#2 Posted : Monday, October 19, 2015 4:30:49 AM(UTC)
ron3033
Fixed, Was able to get range control board from Corecentricsolutions via Eb*y
