Bigmikeq71
#1 Posted : Wednesday, October 14, 2015 9:37:35 PM(UTC)
Bigmikeq71
Was using the self cleaning feature on my Whirlpool #W10198615B and the range sounded like something blew (pop). Oven door is locked and the nothing turns and no power to the range. What could be the problem?
#2 Posted : Thursday, October 15, 2015 1:30:56 AM(UTC)
I cannot find any info on the given model number.
Please check it.
Find your model number - AppliancePartsPros.com
If the stove top elements do not work then check the power.
This is assuming that the unit uses standard infinite switches to control the stove top elements.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Simmer Burners on Thermador Range Stopped Working (Oven Repair (including Ranges and Cooktops))
by Guest 12/1/2021 3:15:27 PM(UTC)
My Range stopped working after self cleaning (Oven Repair (including Ranges and Cooktops))
by Eternalsnshine 10/25/2016 12:17:59 PM(UTC)
Range stopped working (Oven Repair (including Ranges and Cooktops))
by Bigmikeq71 10/14/2015 9:36:36 PM(UTC)
Frigidaire Range Stopped working (Oven Repair (including Ranges and Cooktops))
by callii 11/4/2010 5:17:55 PM(UTC)
Roper electric range stopped working (Oven Repair (including Ranges and Cooktops))
by D Dorey 1/9/2010 7:30:12 AM(UTC)
