The large burner on the stove top will not heat except for a faint bit. I have checked to ensure it is plugged in correctly. Trying to avoid buying unneeded parts. any advice? Tim
I am assuming that all other elements work OK. The most likely cause is the infinite switch. |
THIS FORUM IS DEAD!!!!!!! |
