The ice maker is not making ice for some reason. I have cleaned the ice container and the sensor light seems to be working but, no ice for the last 48 hours. I have not changed the filter for a while could that be a problem for the ice maker?
If the pressure from the water dispenser has decreased then the water filter could be the culprit. It has to be replaced every six months. - The part number for the water filter is AP3182816Gene.
