AnnieB.
#1 Posted : Tuesday, May 19, 2009 1:33:22 PM(UTC)
AnnieB.
My electric dryer will not stay running or heat up. It shuts off after about 20 seconds and beeps like it is done drying. It will not work on any of the settings.
Can you help me figure out which part I need. Thank you.
sidfink43
#2 Posted : Thursday, May 21, 2009 4:51:58 PM(UTC)
sidfink43
Hi Annie
The likely source of your problem is in the control board or the motor. Both are expensive, so I am going to recommend that you review the service manual, link below, and go through the diagnostics to determine if you can isolate the problem to a single component
http://www.servicematters.com/m...ibrary/docs/16026315.pdf
Good luck, and let us know what you find out.
