Age of unit is estimate only. Unit has developed a leak.
have a unit model 175.605520, don't know the age of unit but it has developed a leak. Is repair possible?
Hi there, are you sure about you garbage disposal leakage as the leak could be from anywhere. Well, the leak could be coming out of The sink flang, the dishwasher hose, drain or the bottom. The source of the leak determines how bad the problem is. Thus get it fixed by a good plumber.
