dirtguy
#1 Posted : Tuesday, May 19, 2009 10:27:07 AM(UTC)
dirtguy
tub did not spin. replaced motor coupler. washer works except at end of spin cycle the stop of the tub is so violent that it will move the machine. could reassembly be the problem or does this machine have a problem that caused the motor coupler to go out in the first place.
dirtguy
#2 Posted : Tuesday, May 19, 2009 1:11:17 PM(UTC)
Sounds like there is a problem with brake shoes. The following article on our forum will explain in detail how to diagnose and fix this problem - Replacing Direct Drive Washer Brake Shoes.
