 I have a LG LFX25950sb Frenchdoor fridge that doesnt seem to want to get cold . Air isnt being circulated through the vents in the fridge section . air is being circulated in the freezer but it isnt cold , slightly cool , but not cold .  when i put the fridge in test mode no air seems to be comming out of these vents at all
 but air is currently being blown though the top circular vent that leads into the icemaker . and air is being blown into the freezer section , it is slightly cool but not cold So far i have .. 1. cleaned the condenser coils in the back as well as the fan 2. bought a new pcb board and replaced the old one  3. replaced the relay any help would be much appreciated
These have a tendency to leak the coolant out just after warranty expires. If you can find the evaporator coils inside the freezer section, and expose them, check to see if there is a ball of ice where the coolant line joins the evaporator coils. It could also be that the coils are only slightly frosted at the beginning of the coils. These are both tell tale signs that the coolant has run low. If the evap coils are evenly frosted, and the compressor is running, check the thermistor.
what you are describing is exactly what I see. How do you fix this?
You could get a bullet piercing valve and do it yourself, or call a technician and have them add a charge to it.
