Hi, My saw where my fridge is leaking water down that back wall when I use the water dispenser. I can see the water spraying from the fitting that hooked to the housing. I need to disconnect the waterline from the fitting. Does anyone know how they come apart? Do I compress the fitting and them pull out the hose? thanks
If it is newer, it probably has the compression type fitting. The other fittings look like a white nut. Compression fittings need to be depressed toward the body of the valve, then as it is compressed, pull the line out.
