Hello, I have been trying to repair my freezer on my own. my problem is the freezer, does not maintain the temperature. I set the temperature at 0 degree on the freezer and 34 on the refrigerator. I have purchase a number of part from you company. Heater Metal Sheath, Bimetal Thermostat, water valve, evaporator fan motor. Those are some of the part that I have purchased. still the no solution the problem. The temperature is set at 0 in the freezer, but went I check the temperature I get a reading of 22 to 30 degree. The temperature in the refrigerator is ok. pleased advise.
sincerely: MSGNC99
