powell135
#1 Posted : Tuesday, September 22, 2015 6:58:54 AM(UTC)
powell135
[COLOR="SlateGray"][/COLOR]Getting F13 error code every time I try to use broil setting and when trying to heat oven. It will work for 24 hours then the F13 error shows I flip the breaker and it will work to bake for 24 hours but not broil. I was able to successfully run oven quick clean yesterday. I am a afraid one day it won't work at all? What part do I need?
#2 Posted : Wednesday, September 23, 2015 12:50:17 AM(UTC)
Parts for Frigidaire LES389FEA Range - AppliancePartsPros.com
F13 is a computer problem so the most likely cause is the control board/timer.
