mrfreak64
#1 Posted : Sunday, September 20, 2015 9:57:58 AM(UTC)
mrfreak64
Dryer will heat up in automatic dry mode but will not heat up when on Timed dry mode. What is causing this?
#2 Posted : Tuesday, September 22, 2015 11:53:07 PM(UTC)
Parts for Whirlpool WED5100VQ1 Dryer - AppliancePartsPros.com
The most likely culprit is the timer.
This can be checked by unplugging the unit.
Put it to the timed dry and check across A to B.
It should be 0 ohms.
Be sure to disconnect the wires either from A or B. This prevents you from reading an alternate/parallel circuit path.
