yfegade
#1 Posted : Tuesday, September 22, 2015 8:16:20 AM(UTC)
yfegade
When I start the microwave, the timer countdown starts, I hear few clicks but the turn table does not rotate and microwave does not start (no humming, no heat).
It seems that either the primary/secondary interlock switch or the monitor switch is bad. I suspect it's the monitor switch because when I check the connectivity between the two ends of the monitor switch, it always shows 0 ohms regardless if the door is closed or not. The GE manual says that I have to remove one connector from this switch to check the connectivity, but I don't understand why removing one connector would make any difference (would the monitor switch always show 0 ohms when both connectors are attached?).
Anyways, I tried to remove one connector, but it seems to be stuck. With normal pulling/wiggling I can remove any connectors. I was afraid if I pull hard it would break something and I will have bigger mess.
I wonder, if there is a trick to remove those connectors from the switch.
How do I remove the switch to replace with the new one (Do I have to remove board latch in order to replace the switch)?
I was thinking while the microwave is already open, I might as well replace all 3 switches (if one has gone bad, other two are probably on their way too).
Connectors on the primary interlock switch are hard to remove as well (any trick to remove those).
Appreciate any help. Thanks
yfegade
#2 Posted : Friday, September 25, 2015 6:01:51 PM(UTC)
yfegade
After going through the circuit diagram, I think the monitor switch is fine. I could not test monitor switch by isolating it (by removing one of its connector as GE manual says).
From circuit diagram it looks like the primary switch must be faulty.
Problem is - I can't seem to knock lose the connectors on the primary switch either. Any ideas?
