av8ndoc
#1 Posted : Monday, September 21, 2015 10:59:30 PM(UTC)
av8ndoc
I just need to replace one faulty spark ignition switch. Have seen every web video about opening up the range top of many models, but this model is different from all the rest! burner knobs are on range top, and the console/display is not a backsplash but is between the oven and stovetop. How do I get the whole top open to work in it? Please give detailed instructions or service manual pictures as able and thanks a million!
av8ndoc
#2 Posted : Monday, September 21, 2015 11:28:59 PM(UTC)
av8ndoc
Just read the owner's manual carefully and it says "the cooktop is not able to be opened" -- so now my question is what Jedi tricks do you need to replace the burner control switch -- I guess thru the removed burner pan opening near to it?
wow, what crazy method do I use to service this part?...
