The ice maker is not making ice for some reason. I have cleaned the ice container and the sensor light seems to be working but, no ice for the last 48 hours. I have not changed the filter for a while could that be a problem for the ice maker?
Is there ice or water in the ice mold now? Check the temp of the freezer. Needs to be around 5 or 10 degrees.
the freezer shows 0 which is right. It feels like the ice tray has a little ice in the tray but not much. I called kenmore and they said it might be the filter. I haven't changed it for 8 mos or so.
