wlm273
#1 Posted : Thursday, September 10, 2015 10:37:24 PM(UTC)
wlm273
was working a few min ago then stop, no lights won't drain..
i check the fuse box it is ok, check the drain hole ... no blockage...
what can i do:eek:
#2 Posted : Friday, September 11, 2015 1:56:14 AM(UTC)
See the attachment for a tech sheet.
It looks like this unit does not have a thermal fuse on/by the control board but I would double check this.
You will need a meter to check if the unit is getting power.
Start at the wire nuts in the connection box under the unit.
Note that I have seens cases where theses come loose over the years.
Next would be the door latch switches.
Frigidaire dishwasher code A (Dishwasher Repair)
by Evandtam 6/27/2024 5:11:41 PM(UTC)
Fisher Paykel Drawer Dishwasher will not Lock (Dishwasher Repair)
by thompsdw 6/17/2024 7:34:54 AM(UTC)
Dishwasher won't work. (Dishwasher Repair)
by Guest 5/23/2024 6:32:18 PM(UTC)
High-pitched noise with LG dishwasher (Dishwasher Repair)
by Guest 5/17/2024 5:13:53 AM(UTC)
Cafe Dishwasher little to no heat, not cleaning dishes well. (Dishwasher Repair)
by Jtaylor20 5/16/2024 10:15:38 AM(UTC)
Bosch Dishwasher dirty water in filter " hole" (Dishwasher Repair)
by Guest 5/14/2024 9:47:25 AM(UTC)
Bosch dishwasher SHVM78Z53N/01 (Dishwasher Repair)
by Guest 5/8/2024 8:58:29 PM(UTC)
Continuity TEst Samsung p/n 33299012 Dishwasher Water Inlet Valve. (Dishwasher Repair)
by cprodave 4/27/2024 6:55:56 PM(UTC)
Samsung DMT400RHS Dishwasher Over Level Water Error. (Dishwasher Repair)
by cprodave 4/27/2024 6:24:56 PM(UTC)
Samsung Dishwasher Water Inlet Valve--how to Test? (Dishwasher Repair)
by cprodave 4/27/2024 6:18:51 PM(UTC)
Kitchen aid dishwasher bottom leaking (Dishwasher Repair)
by Guest 4/21/2024 10:31:25 AM(UTC)
Bosch Dishwasher SHE3ARF6UC/22 E15 Error (Dishwasher Repair)
by codyace 3/29/2024 11:51:41 AM(UTC)
GE dishwasher GDT695SSJ0SS middle arm not spinning (Dishwasher Repair)
by merrittjr 3/23/2024 10:51:00 AM(UTC)
Bosch Dishwasher Display Goes Out After Latching Door (Dishwasher Repair)
by Guest 3/11/2024 7:00:18 PM(UTC)
Kenmore 90 665 dishwasher noise from impellor (Dishwasher Repair)
by Guest 3/10/2024 12:30:08 PM(UTC)
