our freezer stopped making ice i set it last night to "Max ice" but that did not make a difference.
nthing seems to be obstructing the moving parts.
I did replace the water filter recently.
the water dispenser is working fine.
is there a reset button perhaps?
Here are your parts Parts for KSC24C8EYYO2 - AppliancePartsPros.comSee the attachments for a tech sheet and a ice maker troubleshooting guide. First check the freezer temperature. It should be around 0degrees F. Also if the fill tube is frozer your water vale may needc replacing. Sometimes they do not shut off correctly letting a few drops of water run out after they shut off. This then freezer at the fill tube tip and overtime build up and clog the fill tube. |
THIS FORUM IS DEAD!!!!!!! |
