Oven coded an F9. Followed previous post by Gene and replaced thermostat on back of oven. It was partially melted and showed no connectivity. The replaced thermostat melted in the same way. The thermistor checked out good as well as the lower heating element and top thermostat. The back heater assembly in showed 34 ohms. What is next? Might have to go with a Pcb assembly? Thank you and God bless us, all.
