b.alford002@comcast.net
#1 Posted : Sunday, August 30, 2015 11:17:11 AM(UTC)
Washer stopped in middle of wash want continue. Power is on, no lights on?
#2 Posted : Sunday, August 30, 2015 12:38:02 PM(UTC)
There are your parts
Parts for Maytag MDB7759AWS4 / Dishwasher - AppliancePartsPros.com
Could be that the thermal fuse (item 5 in section 02) blew.
Check it with a meter.
If blown be sure to use the new wiring harness that comes with the replacement.
balford00@windstream.net
#3 Posted : Monday, August 31, 2015 5:39:43 PM(UTC)
I replaced the switch nothing changed, The lights came back on before repair was made. will not respond to any of the commands.
#4 Posted : Tuesday, September 1, 2015 1:45:52 AM(UTC)
Which switch did you replace.
#5 Posted : Tuesday, September 1, 2015 4:38:04 AM(UTC)
Thanks,
I replaced and used the new harness.
Thermal Fuse Item 5 Sec 2
Model MDB7759AWS4
Billy
#6 Posted : Tuesday, September 1, 2015 5:39:58 AM(UTC)
Did you check the original fuse with a meter to see if it was actually blown?
Do you have the tech sheet.
Sounds like it is most probably a bad control board.
I would check that both door/latch switches are OK.
#7 Posted : Tuesday, September 1, 2015 6:42:58 AM(UTC)
Did not Check Fuse, just took a chance and replaced it. I'm going to order a new board and maybe that will solve my problem. Tks for your help.
#8 Posted : Tuesday, September 1, 2015 1:17:16 PM(UTC)
Replaced the circuit board, touch pad lites work. Touch Resume, lite come on start lite blinks on and off, nothing happens.
#9 Posted : Tuesday, September 1, 2015 1:30:05 PM(UTC)
The tech sheet is too big to upload on this site so I have use a third party site.
Below is the link.
Download MDB7759.pdf
Uncheck "Use our download manager and get recommended downloads"
This should ensure that you do not download any software that you do not want on your computer.
It should help figuring what is going on.
#10 Posted : Thursday, September 3, 2015 7:28:11 AM(UTC)
Thank you very much, decided to call in a repair man.
Guest (6)
