sookeslayer
#1 Posted : Friday, August 28, 2015 2:00:26 PM(UTC)
sookeslayer
I have replaced the pcb 9782455 and reconnected the old jumper P3 to the new board. It should be noted that there are only two ways this jumper connector can be attached to the new board. It has only two pins that this jumper connection can do into P3-1 and P3-4. I have gone through the procedure called "installation Instructions" subtitle "End of Service Test Procedure". This supersedes apparently the Tech sheet in the manual. I have removed the jumper connector P3 totally and tried again with the jumper connector in place exactly like the old board.
The clock works fine but the procedure leads continuously to the F1 E3 error code. There is also no "6AS" preceding the hidden bake: free standing codes
either. It is a gas stove.
With respect to this Repair Forum, I have not seen any new stuff on it so I am wondering if all of this, is for not. Surprise me- pretend you have the board out in front of you and P1,P2,P4, P5 are all plugged in properly. What would you do?
