cooktop2
#1 Posted : Wednesday, August 26, 2015 2:56:31 PM(UTC)
cooktop2
I have a Jen Air JEC8430, a black wire between left front and left rear switches shorted out .. I've repaired the wire, now for either rear burner to work the left front has to be on?? Any thoughts ...
#2 Posted : Thursday, August 27, 2015 1:27:38 AM(UTC)
Parts for JEC8430 - AppliancePartsPros.com
Your model number seems to be missing the last 3 digits so you will have to choose the correct unit from the Matching Model Numbers section.
See the attachment for your tech sheet.
For some reason your fix did not work so now to get L1 (black) to the rear infinite switches/elements it must feed through the left front infinite switch.
May even be the L2 (red) but is more likely to be the black.
You will need a meter to track down the open using the wiring diagram and the wiring layout diagrams.
Be sure to remove power from the unit when doing this.
Remove bosh burners from cooktop (Oven Repair (including Ranges and Cooktops))
by stevekauss 4/8/2024 9:58:44 PM(UTC)
Burner heating without cooktop being switched on (Oven Repair (including Ranges and Cooktops))
by nvreds 2/25/2024 10:40:40 AM(UTC)
Induction cooktop EHI965BA error E9 (Oven Repair (including Ranges and Cooktops))
by Guest 11/28/2023 8:00:28 PM(UTC)
Bosch Induction Cooktop NIT3065/UC Non-Responsive (Oven Repair (including Ranges and Cooktops))
by trishglxk 10/3/2023 9:18:30 AM(UTC)
Whirlpool Electric Range Cooktop Will not Heat (Oven Repair (including Ranges and Cooktops))
by mraupie17 9/2/2023 9:50:45 AM(UTC)
How to remove the sticky screws in GE cooktop? (Oven Repair (including Ranges and Cooktops))
by Guest 4/9/2023 10:34:15 AM(UTC)
removing cooktop control panel on LG double oven (Oven Repair (including Ranges and Cooktops))
by Hurdles 4/4/2023 11:41:26 AM(UTC)
Frigidaire FEF369CGSB - Strange Cooktop Behavior (Oven Repair (including Ranges and Cooktops))
by trymes 3/22/2023 5:59:36 PM(UTC)
Kitchen aid/whirlpool Induction Cooktop Fuses (Oven Repair (including Ranges and Cooktops))
by Guest 12/20/2022 8:42:15 AM(UTC)
THERMADOR COOKTOP PCG366G (Oven Repair (including Ranges and Cooktops))
by pjl2000 11/20/2022 6:48:33 PM(UTC)
Heartland cooktop elements (Appliance Parts)
by Guest 10/11/2022 11:30:11 AM(UTC)
Installing Frigidaire FGGC3047QS Gas Cooktop (Oven Repair (including Ranges and Cooktops))
by Samkat923 8/2/2022 7:26:14 AM(UTC)
Thermador cooktop, no spark or gas for XLO burners (Oven Repair (including Ranges and Cooktops))
by Guest 3/26/2022 5:48:44 AM(UTC)
Cooktop anamoly (Oven Repair (including Ranges and Cooktops))
by RodB 2/17/2022 2:08:20 PM(UTC)
KitchenAid Gas Cooktop Solenoid Diagnosis (Oven Repair (including Ranges and Cooktops))
by Nothing Finer 1/17/2022 9:09:30 AM(UTC)
