jmpnflea
#1 Posted : Monday, August 24, 2015 12:29:15 PM(UTC)
jmpnflea
Aloha everyone! I hope someone can help me here. I encountered the TE error code on my LG washer, did some research online and then replaced the thermistor that I purchased online. Unfortunately, I am still getting the TE error code that rendering my washer inoperable. I checked all my coupling connections again and still have this error code. Most of the postings that I've read with this code and the subsequent replacement of a new thermistor have fixed this problem. Is there anything else that I can/need to check or replace to correct this? I know there is a wealth of information from this community out there so I'm positive I'll be able to fix this!:) Much Mahalo and Aloha from Maui, Hawaii!!!
LG front load washer part id (Washer Repair)
by Cgreen0117 3/24/2024 10:49:09 AM(UTC)
LG front load washer water leak (Washer Repair)
by Guest 7/23/2022 11:17:44 AM(UTC)
LG front load washer making grinding noise (Refrigerator & Freezer Repair)
by Guest 9/18/2021 8:57:25 AM(UTC)
LG Front Load Washer rotor only turns if given a push. (Washer Repair)
by Emailtim 6/5/2020 1:49:05 PM(UTC)
LG Front Load Washer Barely Spins (Washer Repair)
by mckennwa 3/2/2017 6:30:55 AM(UTC)
lg front load washer (Washer Repair)
by melindai 4/15/2014 4:32:46 AM(UTC)
LG front load washer repair- special LG tool to remove the door front seal spring rin (Washer Repair)
by Paul Lukitsch 2/8/2014 10:07:25 PM(UTC)
LG front load washer (Washer Repair)
by reichegw 8/14/2013 10:10:34 AM(UTC)
LG front load washer no power (Washer Repair)
by waxmanak 6/10/2013 11:35:46 AM(UTC)
Leaking LG front load washer (Washer Repair)
by klinkster 6/6/2011 8:27:07 AM(UTC)
Lg Front Load Washer (Washer Repair)
by GIACOMO21 5/19/2011 5:21:43 AM(UTC)
LG front load washer (Dishwasher Repair)
by skimanforu 7/22/2010 3:48:02 PM(UTC)
by Brandon1974 6/7/2009 3:54:12 PM(UTC)
