spidey2442
#1 Posted : Friday, August 21, 2015 2:31:41 PM(UTC)
spidey2442
The problem is that the washer will get to the final spin cycle but will not complete, the clothes will still be heavy wet.
We use the washer twice a week usually 3 loads each time.
We have started unplugging the washer between days of use.
The first load of the day usually completes with zero problems.
Then on the next load the lid lock light starts blinking and it will not complete the cycle.
We have to switch it to just the drain/spin cycle to complete the process on the next loads. This takes multiple attempts at times.
The last two loads last night needed to go through the extra drain/spin cycles to complete.
We unplugged the machine and waited till today to wash a load and it completed with zero problems.
I have no idea....
Any help is greatly appreciated.
spidey2442
#2 Posted : Monday, August 24, 2015 7:34:22 AM(UTC)
spidey2442
Any help or insight at all?
I don't want to start changing out stuff on the off chance it might work.
I started off thinking the lid/lock switch, but after reading various posts I'm unsure.
From what I have read it could also be... Timer?....Actuator?
Like I said in the original post, any help would be appreciated.
Guest (4)
washer will not complete cycle (Washer Repair)
by charligirl305 2/12/2015 11:26:57 AM(UTC)
Kenmore stacked washer will not complete cycle (Washer Repair)
by whovous 12/16/2014 6:28:44 AM(UTC)
Dish Washer Will Not Complete Cycle (Dishwasher Repair)
by hampton girl 9/20/2010 4:43:57 PM(UTC)
Washer will not complete cycle (Washer Repair)
by nicole Jones 11/6/2008 5:59:11 PM(UTC)
