wendyburguress
#1 Posted : Saturday, August 15, 2015 1:28:33 PM(UTC)
wendyburguress
help! dead end of trouble shooting:(
I have the DPSB620EC4ww, it all works great till one day I noticed it does not heat.
I noticed it heated to some certain degree, in a couple of seconds, then after a click sound. It just stop heating.
I took a video and uploaded to youtube.
Please note the click sound then the temperature drop.
https://youtu.be/lWi7MRGT8wo
I went though all the trouble shooting:
as following:
https://www.dropbox.com/s/fz9yjhr3hczh97w/G0511193-00004.JPG?dl=0
https://www.dropbox.com/s/0zhtuo1fhnlm2jy/G0511193-00001.png?dl=0
Please help!
On a side note: I am plugging in the 120v not 240v, it's been working fine for the last 8 years,though.
wendyburguress
#2 Posted : Sunday, August 16, 2015 8:43:49 PM(UTC)
wendyburguress
bump ,any advise?
fairbank56
#3 Posted : Monday, August 17, 2015 7:18:23 AM(UTC)
fairbank56
Groups: Expert
I don't get the "plugging in the 120v, not 240v" part??? The dryer requires 240vac in order to provide heat.
Eric
wendyburguress
#4 Posted : Monday, August 17, 2015 9:04:50 PM(UTC)
wendyburguress
Thanks for reply
I only use the 120v regular, which works fine for the last 8 year.
Just don't know why it suddenly stop working.
The coil did heat up for 5 sec, see my video.
fairbank56
#5 Posted : Tuesday, August 18, 2015 7:38:03 AM(UTC)
fairbank56
Groups: Expert
You need to elaborate on that as it makes no sense to me. How are you able to "select" 120v versus 240v? 240vac is required for the heat circuit to operate normally.
Eric
wendyburguress
#6 Posted : Wednesday, August 26, 2015 6:17:02 PM(UTC)
wendyburguress
Please ignore the 120/240v
It is hooked up 240v, same problem
It heat up, then 5 sec , a click sound from control panel.
Then it stop heating.
Then even I turn it off/on, it does not heat.
I have to completely unplug, then plug in ,to make the same situation happens.
fairbank56
#7 Posted : Thursday, August 27, 2015 5:29:38 AM(UTC)
fairbank56
Groups: Expert
Then it sounds like a faulty control board which is no longer available for this model.
Eric
