LSC26905SW
Woke up this morning to water on the floor in front of the fridge - everything is defrosting in the freezer! Freezer isn't cooling nor is the fridge. What part could this be? Thank you!
Need more info.
What is running and what is not.
Interior lights? Evaporator/freezer fan? Condenser/compressor fan? Compressor? You can usually hear it but also should be able to feel it vibrating. If it is running does it run continuously except when in a defrost cycle or is it short cycling. |
THIS FORUM IS DEAD!!!!!!! |
