Countryhaven
#1 Posted : Thursday, August 6, 2015 6:46:55 AM(UTC)
Countryhaven
Light in fridge works but no power to compressor or anything else.
#2 Posted : Thursday, August 6, 2015 12:03:08 PM(UTC)
Parts for Hot Point HTR16ABSHRCC / Refrigerator - AppliancePartsPros.com
You may be stuck in a defrost cycle.
Note that most defrost cycle last about half an hour.
If it has been longer try turning the defrost timer cam with a screwdriver.
It only turns in one direction.
Also there is usually a hole in the cover to let you do this without taking things apart.
If the unit fires up then replace the timer.
