rdennison
#1 Posted : Monday, July 20, 2015 8:12:43 AM(UTC)
rdennison
The dishwasher seems to run fine during all wash cycles however when it starts to drain it makes sort of a grinding sound. It appears to drain out ok but not without this new noise. I'm wondering if this could be the drain pump? I would appreciate any advice I can get. Thanks in advance.
Ryan
CletusT
#2 Posted : Wednesday, August 5, 2015 4:23:03 PM(UTC)
CletusT
Mine did that because there was something banging around in the pump.
Also, the chopper could be loose, or cracked (impeller).
