VA_DIY
#1 Posted : Friday, July 31, 2015 10:06:14 AM(UTC)
VA_DIY
With ice forming around the coils, i replaced both timer and thermostat. With the unit almost 30 years old, i think it is the safe thing to do. Would have changed the heater element also except that part is no longer available.
I have a cheap anolog multitester with only 2 settings for ohm ( X10 and X100 ). When i tested the old timer(PN 945514) , the reading is infinity for all combinations so i figured it must be bad. But i get the same readings with the new timer (PN 482493) as well. Do i need a better multitester to measure the timer ?
For the new timer, i connected the loose black wire to Pin 2.
After replacing timer and thermostat and let it run overnite, the ice is still forming around the coil. The new timer does not seem to run , based on my ink markings.
Any suggestions would be greatly appreciated. Thanks in advance.
CletusT
#2 Posted : Sunday, August 2, 2015 7:45:29 PM(UTC)
CletusT
The fridge will most likely only defrost every 12 hours anyway. If there is ice on the evap coils, ICE not frost, there may be a system leak.
When the coolant gets too low from leaking, a ball of ice will often form on the evap coils, otherwise, there should only be a fairly thin layer of frost on it until it hits defrost cycle.
Also need to test the defrost heat element for Ohms. No reading on the meter means bad element.
#3 Posted : Monday, August 3, 2015 3:28:43 AM(UTC)
I am not sure what your problem is.
I cannot find a wiring diagram for this unit so I do not know if the timer is wired as continuous or cumulative.
In cumulative it will only advance when the compressor is on.
By ice do you mean ice or is it frost.
For it to be a defrost problem the evaporator/freezer coils have to be iced/frosted over to the point that the evaporator fan cannot pull air through them.
See the attachment for the tech sheet which should have come with your timer.
So pin 1 to 4 or 1 to 2 should be 0 ohms depending if the timer is at run or defrost position.
Also 1 to 3 timer motor winding) should have some resistance though I do not know how much.
One way to check the meter is to short the meter leads together before starting so you can see that is does read 0 ohms.
I need more info on what is working and what is not.
Also on what the frost pattern looked like on the evaporator coils and any other symptoms which may help troubleshoot the problem.
VA_DIY
#4 Posted : Tuesday, August 4, 2015 2:08:34 PM(UTC)
VA_DIY
First of all, thanks to cletusT and denman for your inputs.
Denman, it was lots of ice, to the point that frozen foods were thawing.
Attached is the schematic diagram.
Based on this schema, i connected the loose black wire to Pin # 2.
In the old timer, there is a green wire that was connected to a side pin. This side pin does not exist on the new timer. I leave that green wire alone, unconnected to the new timer. It seems like a ground wire to me ?
I did not bother to cut the heater wires and test the heater element because that part is no longer available. Should I do that anyway ?
I double checked a few times yesterday and the timer indeed did not turn at all ( by comparing the marking i made on the gray knob? that is used for manually advancing the timer ).
For now, i set the temperature to the lowest setting and I haven't had to use the heat gun for the last 2 days to de-ice the evaporator coil.
In the first few days with the temp knob still set to high, there was definitely ice.
Again, thanks to all that responded.
File Attachment(s):
Freezer Model 106-8263380.pdf (1,314kb) downloaded 1 time(s).
