sparkync
#1 Posted : Saturday, August 1, 2015 12:10:39 PM(UTC)
sparkync
I'm having trouble with my Whirlpool oven. I'm getting a F2-E3 code. I've checked the oven tempertrure sensor and it ohms out alright. Next possibility my paper work inside range says, is that it may be a relay welded shut. All the relays are on the circuit board the best I can tell. In continuing checking this out, I found out the "latch motor" should have 2850 ohms. I'm only getting 1862 ohms. Is there any way this could have an affect on the F2-E3 code. When this code comes up the door latches and I have to turn the power off to get it opened. I'm still checking it, so I want to verify that later.
Thanks.
#2 Posted : Sunday, August 2, 2015 3:46:45 AM(UTC)
I doubt that the motor is the problem as it does work to latch the door.
