macd2x
#1 Posted : Saturday, July 25, 2015 7:15:12 PM(UTC)
macd2x
My dishwasher is stopping mid-cycle, about 10 minutes in, with all the lights off. I can restart it, but it stops again.
It fails in this way in ProWash mode, but will run all the way in 1-Hour-Wash mode.
Entering diagnostic mode, I get the error code 6-1.
Guessing it was the control board, I contacted KitchenAid and they sent me a new one under warranty. I replaced the board. The first load through worked fine. Woo-hoo! But, then the second load stopped mid-cycle, still with diagnostic code 6-1.
Could the new board also be bad? What else can I try?
CletusT
#2 Posted : Wednesday, August 5, 2015 4:20:14 PM(UTC)
CletusT
Maybe the water temp in that cycle isn't getting hot enough to satisfy the machine.
Does the heating element get hot enough during the cycle?
#3 Posted : Thursday, August 6, 2015 5:10:55 AM(UTC)
Parts for KitchenAid KUDE60HXSS2 Dishwasher - AppliancePartsPros.com
I doubt that the new board is bad.
Too much of a coincidence that it would give the same error.
Also check the other possibilities under the 6 function.
Check that the unit is draining correctly.
Check the overfill float switch. It should always be activated (closed) as it is just an overfill safety device.
macd2x
#4 Posted : Sunday, November 8, 2015 7:43:05 AM(UTC)
macd2x
Turns out the screen of the fill valve became partially clogged with sediment. I replaced the valve and all is good. I may have been able to clean out the screen with the same result.
jgfalk
#5 Posted : Sunday, January 1, 2017 3:53:30 PM(UTC)
jgfalk
I was having a similar problem. Then about 2 weeks later my water heater gave out. Once I got it replaced, the dishwasher worked fine. It had something to do with the water temperature - so just wanted to pass that along.
Guest (4)
