Phillip123
#1 Posted : Friday, July 24, 2015 11:31:55 AM(UTC)
Phillip123
Can anyone help me with the bake burner problems im having.
The burner will light and get to temp if the oven is cold.
If i try to use it after that it will try to light but after the gas turns on the igniter clicks 4 times it stops and will try 2 more times. Then it stops altogether and i have to push stop and start the darn thing over again.
The broiler works everytime and the 5 burners on the stove top work everytime.
I read about testing the ohms on the gas valve needing 216 ohms. With a plus or minus 10 percent. I got 195 on bake terminal and common and 198 on broil and common.
My readings were on a digital meter and checked several times so im sure their correct. But at the low end of the scale so im really not sure where to go from hear.
The gas valve was replaced several years ago but i dont remember why since i was working all over the us back then and just paying the bills. You know. Wife says Its broken. I tell her to call and get it fixed..
Back to The problem. All the wiring is good and the igniter and burner are clean and look like new. Im not wanting to spend hundreds of dollars on parts for the heck of it to eliminate things. And the repair shop here wants too much just to show up and test everything ive already checked at 65 bucks an hour.
Please help and thank you.
Problem with oven burner (Oven Repair (including Ranges and Cooktops))
by StNick55 11/5/2008 2:47:59 PM(UTC)
