I had the thermal fuse blow on my washer that I replaced. Now I get an error code of 1 flashing light on the motor which is for the tub. I've followed the instructions for resetting the error code 10 times in various ways the the code will not clear.
I've verified the lid switch and everything else for the motor. I'm only getting 65 ohms for the shifter instead of the supposed 98. Though my multimeter is pretty bad.
It's also making a very audible clicking sound along with the light flashes. *click* *led on* *led off* *click* *pause*. Should I give up and buy a new washer?
Let's see if we got any ideas=) Inverter board flashes 4 times on mine so I replaced the mode shifter and I still have same error flashing. Can I pop a new motor in, or could it be something else? Thank you anybody! Lol
